Case IH indicator lights
/ Case IH indicator lights #1
savantu
Arad, Romania
Fiatagri 180-90
Hello,
I want to buy a Case tractor but it has 2 lights on the dash board. Can you tell me what they mean ?
Thank you!
/ Case IH indicator lights #2
The amber diamond is designed to flash in order to call attention to any conditions requiring attention. The red light is a bit blurred on my small screen, but looks like the low brake fluid indicator.
Thank you for your reply. The mechanics from the vendor ( which is a Fendt one - they have little know how with Case and no tools to diagnose it ) said the light is on because the air bottle for the brakes is empty, the compressor belt is removed on that tractor. I was afraid of something more serious with the brakes ( they seem to function well ). Does it have a sensor for air pressure ?
/ Case IH indicator lights #4
Tractors sold in this country don't use air brakes, so if yours has air operated systems, I couldn't tell you how to troubleshoot. The only type I'm familiar with are hydraulic brakes, which have a small reservoir under the hood supplying fluid to the brake master cylinders. The cap has a switch and float assembly with two wires connected to the warning light circuit.
/ Case IH indicator lights #5
Yes, the yellow is a warning that could mean a number of things, from a fault to something that needs to be calibrated. It appears that the red light is an indicator that the air brake pressure is low. There is a switch in one of the air tanks. The air is only for trailer brakes, the vehicle brakes are independent and operate hydraulically.
/ Case IH indicator lights #6
Tractors sold in this country don't use air brakes.[/QUOTE
They just started, but air brakes are an option on the new CaseIH magnum tractors in North America. I'm not sure about the other guys, but I would bet if they don't already they will soon.
2015 Chevrolet Equinox SUV (A64557)
2015 Chevrolet...
KMC 14' FIELD CULTIVATOR (A64278)
KMC 14' FIELD...
2023 SANY SY225C EXCAVATOR (A63276)
2023 SANY SY225C...
2023 GERINGHOFF PATRIOT RD8R30" CHOPPING CORN HEAD (A64278)
2023 GERINGHOFF...
2017 Ford Explorer AWD SUV (A64557)
2017 Ford Explorer...
2021 Mac Trailers T/A Walking Floor Trailer (A64556)
2021 Mac Trailers...
