Case IH 595 New Ignition won't work!
/ Case IH 595 New Ignition won't work! #1
gekog
Oliver BC, Canada
1991 Case IH 535
I have a 1991 Case IH 595 with cab. It has heat and air and a radio. I had to replace a the ignition in it because the key broke off inside it and I couldn't get the piece out. The new one plugged into the harness perfectly. Problem is that nothing happens when I try to start the tractor. Not with the key in the auxillary position or any other position. No dash lights....nada. My first thought was that in messing around, I had blown a fuse, but they all seem good. I do see 3 Bosch relays near the fuse box, (all identical) but even if I could check them I wouldn't know how, and I hate to buy a relay unless I am pretty sure that's the problem. The fuses I checked and the 3 relays are under the top of the dash. Am I missing something obvious?
Thanks to anyone and everyone who can think of what might be wrong here.
Geoff
/ Case IH 595 New Ignition won't work! #2
Your next investment should be a testlight, not a relay. You need to verify the circuits to and from said key switch
/ Case IH 595 New Ignition won't work! #3
take the old switch and test with a oms meeter then do the same with the new switch .. you may have got a dud .. my 684 IH , the stinking light switch cost $134 ...just for a stupid light switch . thats nuts . so when it gets dark i shut things down .lol good luck
PORTA COOL 2000 PORTABLE EVAPORATIVE COOLER (A59823)
PORTA COOL 2000...
PT Portable Cow Feeder (A60463)
PT Portable Cow...
MORBARK WOOD HOG 6400 XT HORIZONTAL GRINDER (A60429)
MORBARK WOOD HOG...
3PT 10' Rolling Cultivator (A60463)
3PT 10' Rolling...
2014 Ford F-550 Altec AT40M 40ft Material Handling Bucket Truck (A61568)
2014 Ford F-550...
2019 ALLMAND LIGHT PLANT (A60736)
2019 ALLMAND LIGHT...
