Case/IH 385 clutch? slips in high range
   / Case/IH 385 clutch? slips in high range #1
geneP
Platinum Member
Central Mississippi, USA
Case-International 385, Kubota L5450 w/LA1150A loader
I have a friend with a 385 Case/IH tractor with about 1500 hours on it and he has owned it since new. It has the basic transmission with no power shuttle, etc. He tell me it acts like clutch is slipping in high range but doesn't in low range no matter how much it is loaded. The question is: is there anything in the transmission that could cause these symptoms before he tears into the clutch?
   / Case/IH 385 clutch? slips in high range #2
Sounds like worn clutch plates to me.
This is an old thread, my friend had the clutch replaced and all is good.
   / Case/IH 385 clutch? slips in high range #4
Does the clutch pedal have any free play? If not adjust linkage for 3/4 to 1 inch free play.
   / Case/IH 385 clutch? slips in high range #5
Hello all,
I have a CIH 385 and the tractor foes not move when clutch is released. I have adjusted the free play. This is a 4 x 4. Do you think it is the clutch? Is it difficult to replace? Many thanks.
   / Case/IH 385 clutch? slips in high range #6
Ontop of another very old tread.
Start your own thread.
It can only be your clutch.
2020 CATERPILLAR 299D3 SKID STEER (A52709)
2020 CATERPILLAR...
LOT: (4) Jack Stands (A59076)
LOT: (4) Jack...
2022 Wacker Neuson PDT2A 2in Portable Diaphragm Pump (A55851)
2022 Wacker Neuson...
POLY TOTE W/ WIRE CAGE (A58374)
POLY TOTE W/ WIRE...
2018 John Deere 470G Hydraulic Excavator (A56857)
2018 John Deere...
CAT 777B ARTICULATED DUMP TRUCK (A58214)
CAT 777B...
