Case IH 3230 clutch rattle in neutral?
   / Case IH 3230 clutch rattle in neutral? #1
cdodson21
Sneedville, TN
case ih 3230 John Deere 6110 New Holland 3930
So I just bought a 1997 case ih 3230, but have not picked it up yet. when testing it everything seemed fine except for when in neutral and the clutch released it rattles. has 8x8 shuttle. wasn't too worried about it, but was wondering if anybody had any ideas.
   / Case IH 3230 clutch rattle in neutral? #2
Clutch should not rattle!!
Just a thouht!! If the engine low idle tickover is too low you can get a rattle from the gearbox syncroniser plates ??
Low idle should ideally be 800 to 850 rpm and on this 3 cyl engine is better at 850'. It is vibration fron the 3 cylinder engine that causes the syncro plates to rattle at low engine rpm??
Do you need a service manual?? I do a manual as a PDF down load and accept payment through PayPal !! Drop me a P M with your e mail address for deatails!!
It's a 4 cyl engine and it does it at all rpms.
   / Case IH 3230 clutch rattle in neutral? #4
Under the bell housing is a metal plate, just to the rear of the engine/ transmission joint, remove this and hav a look at what you can see, a powerful torch or work light will help!!
ok. I'll give it a check. maybe just a throw out bearing
2011 Toyota Camry Sedan (A56859)
2011 Toyota Camry...
New Wolverine 3Pt hitch Receiver (A59000)
New Wolverine 3Pt...
AUCTION STARTS HERE @ 9AM (A52709)
AUCTION STARTS...
2017 Ford Fusion Hybrid Sedan (A56859)
2017 Ford Fusion...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Case-IH 370 Steiger (A57148)
Case-IH 370...
