Case IH 275 Starter selonid
   / Case IH 275 Starter selonid #1
Steven Jencso
Hi
Can any one recommend a replacement selonid for the starter motor? Case wants $250.00 for one.Case part # 1962785c1, It is a bit steep in my book. I went to NAPA but they could not help.
Any suggestions?
Steve Jencso
   / Case IH 275 Starter selonid #2
Post on the Mitsubishi forum. The 275 is a Mitsu and someone there will know about a possible parts interchange.
   / Case IH 275 Starter selonid #3
Have you found any good info on this? I replaced the selenoid in my 275 with one that a local repair guy (alternators and things like that) found. It says on the selenoid that the part number is 7-784/66-8331 and it seems to be made in Brazil by WAI ZMS.A
Not sure if you can find anything with those numbers but it cost around 50.00, I also didn't want to pay the 250 that case wanted. If you don't have any luck with that try contacting a local business that repairs alternators and things like that.
Not sure if this would help, but I replaced my selenoid because I the starter wouldn't engage, I would just keep getting that "click" sound, after I replaced the selenoid it still happened, turned out it was the safety switch on the range selector, if I didn't push that all the way into Nuetral it wouldn't start. Might be something to check if you haven't already. After that I was glad i didn't buy the 250 dollar one. Hope that helps.
Hi Piston
I had the same luck after replaceing the selonid. I jumped out the range selector switch. Same thing. It might be the PTO saftey switch I Just found it. Did you have any luck finding a aftermarket saftey switch case # 1271754C1?
I think Case dose not want to keep there customer base as there parts are very costly. Cannot find any gold on the parts
Thanks Steve Jencso
   / Case IH 275 Starter selonid #5
It actually turned out that there was just some lose wiring for my safety switch, once I cleaned up the connections and tightened it all back up I haven't had any problems since.....yet that is.....so no I hadn't looked for the switch.
   / Case IH 275 Starter selonid #6
Good luck and please post your findings. Im having the same trouble with my 244. Replaced the solenoid and still problems. Im going to start cleaning connections tomorrow. Thanks.
   / Case IH 275 Starter selonid #7
Just replaced starter and am troubleshooting some other stuff on my 244. I got great service and price from Nations alternator. BTW what type of oil is recomended for IH 244?
2017 FREIGHTLINER M2 S/A SWEEPER TRUCK (A51406)
2017 FREIGHTLINER...
J and L Cargo Express Shadowmaster Enclosed Trailer (A51039)
J and L Cargo...
2009 International Frazer Bilt X-514 Ambulance (A49461)
2009 International...
2019 Ford F-450 4x4 Crew Cab Gooseneck Flatbed Truck (A49461)
2019 Ford F-450...
WITTIG VACUUM PUMP (A50854)
WITTIG VACUUM PUMP...
2012 FORD F250 (INOPERABLE) (A50854)
2012 FORD F250...
