Case IH 245 cannot shift
   / Case IH 245 cannot shift #1
djuser
oxford,mi
case
(235/245 3cyl diesel Mitsubishi?) I was plowing snow and going back and forth from 2nd to Reverse often. Also pulling a blade in 3rd. (Range Medium). After about an hour, shifting down left for Reverse started "missing" and staying in N or 3rd. Then later got stuck in Reverse. Eventually it doesn't shift at all. I can move the handle up/down a bit with effort but not the normal "H" (1,2,3,R)action and doesn't shift into a gear like normal. When I release clutch the engine just slows/stalls. I'm able to roll the tractor with engine off with range lever in start/neutral, but makes a ticking noise while towing/rolling. That noise goes away with the clutch depressed. Hydraulics work. Any ideas? Thanks
I did check oil and was half quart low, hydraulic fluid full. Added oil and it does start and engine runs fine. Maybe shift linkage? transmission? Thanks!
   / Case IH 245 cannot shift #4
I don't know your tractor but it could be your shift linkage. The tractor may be in two gears at once. Something could have slipped or broken inside the transmission itself.
2016 Ford Fusion SE AWD Sedan (A53424)
2016 Ford Fusion...
2003 Mack CH613 T/A Day Cab Truck Tractor (A52377)
2003 Mack CH613...
2017 HITACHI ZX350LC EXCAVATOR (A54607)
2017 HITACHI...
2015 Ram 3500 Enclosed Service Truck (A52377)
2015 Ram 3500...
5TH WHEEL HITCH (A53843)
5TH WHEEL HITCH...
U56 ELECTRIC FIRE PUMP (A51406)
U56 ELECTRIC FIRE...
