Case Farmall - A tractors
   / Case Farmall - A tractors #1
WayneJessie
Does Case produce these tractors/engines themselves or do they have them made by an outside source? Not familiar with the new ones.
   / Case Farmall - A tractors #2
They are all imported engines. Depending on the HP range it could be a Jap motor on the 45 and 50HP...an ISM. If its the higher HP models it will be an engine out of Italy thats assembled in India...an Iveco.:cool:
   / Case Farmall - A tractors #3
I have one have a little over a hundred hours on it been great to me so far
   / Case Farmall - A tractors #4
Depends on the power and series. The older DX was a ISM engine made in Japan. The A series and what was the JX series are Iveco based engines from FTP, (FIAT Power Trains). These engines are in the Case IH family, as FIAT is the parent company of both Case IH and Iveco. Until a short time ago, Iveco and Cummins had a joint venture called CCD, so some engines in the Cummins line has Iveco DNA, including the Cummins diesel in Dodge trucks, which FIAT is the managing partner of Chrysler Group. It is a very integrated world. Iveco makes a very good engine, and the ISM is a stout product as well. The newer small tractors replacing the ISM based products will be L S made in Korea I think.
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
2019 MACK GR64F TANDEM AXLE CEMENT MIXER TRUCK (A52577)
2019 MACK GR64F...
Coleman Go Cart (A51573)
Coleman Go Cart...
2013 KENWORTH T800 DAY CAB (A53426)
2013 KENWORTH T800...
2012 Ram 3500 4x4 Dump Truck, VIN # 3C7WDTAL9CG134341 (A51572)
2012 Ram 3500 4x4...
2000 GMC C7500 Flatbed Truck, VIN # 1GDM7H1C4YJ505285 (A51572)
2000 GMC C7500...
