Tractor Sizing Case Farmall 75c with R4 tires
   / Case Farmall 75c with R4 tires #1
retiredwill
Worden, Illinois
NH TC 33D. International 1086.
I'm currently seriously looking at purchasing a Case 75c. I think that R4 tires would work best for me. I have a big problem finding a good picture of a Case 75c with a cab and R4 tires. Searched the Internet for hours, checked with several dealers. No luck. Can someone help me. Wil
   / Case Farmall 75c with R4 tires #2
What will pictures help you with ???
Hi TSO. I just like to see how low the Case 75c sits when equiped with the R4 tires. The standard rear tire for a 75c is 16.9-30. The R4's are offered in front with a 12.5/80-18 and the rear with a 16.9-24 or 19.5L-24. I assume that the Tractor sits about 6 inches or so lower with the R4's. I also asked the local dealer if the R4's can be adjusted for width like you can with the R1's. He has no answer for me.
Thanks MtnViewRanch. That is a pretty good picture.
   / Case Farmall 75c with R4 tires #6
I'm NOT looking through all of these 75C picts. to see if the exact pict. you want is there, but you can!
Bing Images
SR
   / Case Farmall 75c with R4 tires #9
If I remember correctly the 19.5L has a taller sidewall and will give you more ground clearance. Be careful with the pictures the 75c use to have a low profile version. So make sure you aren't looking at at LP. The fenders are different.
   / Case Farmall 75c with R4 tires #10
I don't understand why you want to "low ride" your new tractor, but if you use your imagination, you can see the small-tired tractor in your mind. I did not look up any tire sizes but if your chosen tires are 12 inches shorter than stock, the tractor will sit 6 inches lower. That means 6 inches less ground clearance, and 6 inches less tire in the fender well. This also means a 6 inch lower center of gravity and significantly lower gear ratios due to shorter tire rolling distance. It also works the same (but opposite!) way when going to a taller tire.
On a 4wd tractor, you want to keep the same size ratio differences between the front and rear tires to keep from binding (and possibly breaking) front axle, drive shaft, and/or transfer case, and also to keep the tractor sitting level (this last part also applies to 2wd tractors too). Good fortune!
Scott
2019 Kohler 50REOZK 50 kW Diesel Generator (A56857)
2019 Kohler...
TRANSMISSION JACK & TRACTOR CYLINDER (A54757)
TRANSMISSION JACK...
MAGNUM LIGHT TOWER (A58214)
MAGNUM LIGHT TOWER...
2016 Ford F-150 4x4 Pickup Truck (A54814)
2016 Ford F-150...
BOSS MT 660 Fuel Trailer - 660 Gallon Mobile Diesel Tank, DOT-Approved (A55315)
BOSS MT 660 Fuel...
2008 FORD F-350 SUPER DUTY BUCKET TRUCK (A58214)
2008 FORD F-350...
