Case DX55 Clutch
   / Case DX55 Clutch #1
jduke
Bronze Member
I have had my tractor for about 10 years. It is a 2004 model. It had 410 hours when I got it and now it has almost 700 hours. The issue I have is that twice in the ten years I have owned it, I have had to make the clutch adjustment rod longer. The problem is that I'm almost out of threads on it. I assume this means that the clutch is worn? I know its time to adjust the clutch because at a certain point, you can feel the tractor 'slipping' as though the clutch is partially engaged. A turn or two of the rod, and its good to go again.
It has spent most of its life with a 850lb shredder on the back and a 6' heavy duty grapple on the front. I do a LOT of grapple work on my place, LOTS of forward and reverse and clutching. I am very mindful of 'riding the clutch'.
My questions are:
How long should a clutch last in a tractor like this?
Can I replace the clutch myself and will it lose all its hydraulic fluid when making the repair? I believe it is a 'dry' clutch.
   / Case DX55 Clutch #2
All depends on the world you are doing and a lot of forward reverse is a killer for a clutch !
   / Case DX55 Clutch
Makes sense. I figured its wear was related to that kind of work. Any idea on clutch replacement? Can I split this tractor without losing any fluid? My gut says yes, but I have no clue how its put together inside.
   / Case DX55 Clutch #4
you will lose fluid, not from clutch but all the lines that have to be taken apart
2016 SDLG L948F WHEEL LOADER (A51242)
2016 SDLG L948F...
PENDING SELLER CONFIRMATIONS (A51219)
PENDING SELLER...
Vacuworx MC3B Vacuum Lifter (A50860)
Vacuworx MC3B...
2021 Chevrolet Silverado 1500 LT Crew Cab Pickup Truck (A48081)
2021 Chevrolet...
2022 Forest River Coachmen Apex Ultra-Lite 245BHS 27ft T/A Travel Trailer (A48082)
2022 Forest River...
2013 Acura RDX AWD SUV (A48082)
2013 Acura RDX AWD...
