CASE Dx34 - Oil Change question
/ CASE Dx34 - Oil Change question #1
ColbyCulbertson
Case DX34
I bought a used 2006 Case Dx34 at an auction a few weeks past. There are two questions to this post.
1. I was using the tractor for some light work around the property, just testing it out and seeing how it runs. Everything was running great, and then I started to hear a light knocking, the knocking gets louder and faster as the throttle pushed to higher RPM's. Thoughts on what this could be?
2. Was changing the oil, and noticed there is an engine oil fill on top of the engine down below teh gas cap. There also appears to be a second fill on the side of the engine on the right hand side? The cap is completley warn so I don't want to add oil through here unless I am 100% confident that is a second fill section. Anyone know if this is indeed a second area to fill the oil or if its for different flueds?
UPDATE for anyone with the same tractor: The fill port on the right side of the tractor is a secondary fill port for the engine oil per a tractor mechanic.
2020 International HX620 Quint Dump (A62613)
2020 International...
2020 Club Car Carryall 700 Gas Utility Cart (A61567)
2020 Club Car...
TERRA TRACK TRACKED WORK  VEHICLE
TERRA TRACK...
New Holland TC21 (A62177)
New Holland TC21...
2020 KOMATSU D65EX-18 CRAWLER DOZER (A65053)
2020 KOMATSU...
Deutz-Fahr 6140 (A64126)
Deutz-Fahr 6140...
