Case DX29, hydraulics stopped working
   / Case DX29, hydraulics stopped working #1
levi.b.martin
Case IH DX29
I did a hydraulic oil and filter change, just part of the 300-hour maintenance, and now the arms and 3-point hitch won't raise. We blew air into the oil reservoir and bled the lines, but the arms still don't raise; I'm unsure if the pump is working.
I'm new to working on tractors, so don't rule out anything that might seem obvious.
   / Case DX29, hydraulics stopped working #2
Unless you changed the transmission oil the 3 point shouldn't have been effected.
   / Case DX29, hydraulics stopped working #3
Is your hydraulic fluid reservoir full, does it have a dip stick or a view port?
If you loosen your hydraulic spin on filter does oil flow out of it.
Is your pump external with a visible suction line? If so can you loosen it and see if you have fluid to the pump.
Or loosen the line leaving the pump and try turning the engine over and watch for fluid leaking.
quite a difference in hydraulics depending on the transmission is your geared or hydrostatic
geared,
hydro;
BANDIT 2550 50HP WHEELED WALK BEHIND STUMP GRINDER (A51242)
BANDIT 2550 50HP...
Cat 277 Skidloader (SALVAGE) (A50774)
Cat 277 Skidloader...
2025 78in Dual Cylinder Hydraulic Grapple Rake Skid Steer Attachment (A50322)
2025 78in Dual...
2018 WOOD MAXX TM 86H WOOD CHIPPER (A51243)
2018 WOOD MAXX TM...
2011 JOHN DEERE 310SJ BACKHOE (A51242)
2011 JOHN DEERE...
1992 Imperial Trailer (A50514)
1992 Imperial...
