Case DX-40 pumped engine full of hydraulic oil !
   / Case DX-40 pumped engine full of hydraulic oil ! #1
cpeters
I posted the below in the Case IH forum and got a helpful response from Jnman was just interested if anyone had ever had this happen. I talked to my local Case IH dealer mechanic and he said they had never had this happen. I will pull the pump this weekend.
Brush hogged for 4 hours yesterday and all was good but today I was taking my Case DX-40 to the barn and as I pulled in noticed an oil trail going into the barn.
Started looking around thinking I had a metal fluid line cracked...while looking I ran the engine up and it started spewing hydraulic fluid out of the crankcase breather hose from the top of the valve cover!!! Talking about filling an engine!
Obviously I immediately shut the darn thing down right then.
I would have to suspect some sort of seal in the hydraulic pump on the front of the engine let lose and is pumping hydraulic fluid into the crankcase. I guess the only positive thing is at least it is not water in the crankcase, so I would expect the engine will be fine after an oil and filter change.
Have any of you experienced this?
Pump rebuild? or new Pump? am I off base here.....guess I'll pull the pump this week.
GRRRRR.. Last summer I had to replace cracked oil cooler after puking fluid all over.
Thanks in advance for any advice.
By the way it has about 2800 hours on it.
Charlie
   / Case DX-40 pumped engine full of hydraulic oil ! #2
A couple of pics of the hyd pump would help....back in the 50s/60s/70s/ Farmalls came with a hyd pump run off the distributor cam. Two metal line ran from there to the hyd block...Once in a while one of the lines, I believe the high pressure side would blow an O-ring letting the hyd fluid get in to the crankcase....Actually it was a simple fix back then...take off the pump and replace the 2 O-rings...problem solved...Hopefully your situation won't be any more bothersome. Good luck and let us know how it turns out. BobG in VA
Pulled the pump this weekend and as suspected the front shaft seal is definitely broken, I pulled the rest of the pump apart and no wear at all looks brand new, although some of the gaskets between the pump end plates, sort of a figure 8 looking gaskets on the front and back plates seem to be a little ate up in places. The tractor 3 point would always leak down so maybe I have had a little issue for a while.
I know NH and Case so not show a gasket kit for the pump but I am going to replace them all hopefully. It is a KYB pump and I have the pump number. I found some places on line I will try to call that deal in pump gaskets and parts. If I can get the parts it should be a simple fix...otherwise I will try to cross the part number on just the front shaft seal.
Thanks for all of your help.
Charlie
   / Case DX-40 pumped engine full of hydraulic oil ! #4
Good on ya! Hopefully the gaskets/seals will fix your problem. Let us know the outcome. BobG in VA
   / Case DX-40 pumped engine full of hydraulic oil ! #5
Hopefully it seals.. sometimes a lil wear develops and shaft seals won't hold.. other times shaft seals let go due to deadheading.. like from a bad QD connection.
At least your crankcase will likely be VERY clean.
Good luck... post back and let us know how it went.
soundguy
City of Buckhannon -Onan 50 Set Stand By Generator (A52384)
City of Buckhannon...
2001 Blaw-Knox PF 150 Paving Machine (A52384)
2001 Blaw-Knox PF...
2015 FREIGHTLINER CASCADIA DAY CAB (A52577)
2015 FREIGHTLINER...
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
MALONE 3000TP LOT NUMBER 229 (A53084)
MALONE 3000TP LOT...
2010 Chevrolet Impala Sedan (A51694)
2010 Chevrolet...
