Case David Brown 1210 won't shift
   / Case David Brown 1210 won't shift #1
Laneman950
Texas
John Deere 950
This one is for sale locally. Ad says it won't shift, and hasn't been run in several years. No other info, but price is at $800. What do y'all think? I sure could use a tractor in this price range if the repairs aren't too difficult. I have pretty good mechanical skills but have never repaired a tranny.
   / Case David Brown 1210 won't shift #2
I have a 1210 and am fairly familiar with them. The synchronizing method in the 12 speed transmission uses some fairly small springs (6 of them) that will rust away if the fluid is not kept clean. So if you have a problem getting it into 2nd or 3rd, that's probably what it is. If it won't shift into any gear, then I'd say that the shifter pawls themselves are worn or broken.
   / Case David Brown 1210 won't shift #3
I have a 4wd 1210 DB Case and the hydrolics dont seem to workwhat levers and knobs do I shift to make them go
Auger Drill Bit (A56857)
Auger Drill Bit...
2020 MACK PINNACLE (A58214)
2020 MACK PINNACLE...
2017 FREIGHTLINER CORONADO SD122 DAY CAB (A56138)
2017 FREIGHTLINER...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55851)
iDrive TDS-2010H...
HIGH END MINI GOLF CART (A58214)
HIGH END MINI GOLF...
2015 Nissan Pathfinder 4WD SUV (A56859)
2015 Nissan...
