Case backhoe def. lock
   / Case backhoe def. lock #1
Giles Gurley
Alabama
Case 480D TLB--364 I.H.
I have rebuilt the brakes on the left side of my 480D Case backhoe. I am in the process of rebuilding the right side. My parts book only shows one seal to prevent contamination of the brake discs. There was oil contamination just like the left side so the seal is being replaced. My question is---How does the deff. lock get it lubrication or is it designed to run dry?--(doughtful) !
   / Case backhoe def. lock #2
Giles, I am not 100% sure so I won't say anything but forward your question to here:Tractor/Loader/Backhoes - Heavy Equipment Forums and you'll get an answer. There are 2-3 Case Reps on here, I think all 3 are mechanics for over 20 years with Case and they'll get you an answer.
Blake
WA
2025 Swict 72in Bucket Skid Steer Attachment (A51691)
2025 Swict 72in...
2015 Ford F-750 Liftmoore 2550 5,000LB 2.5 Ton Crane Mechanics Truck (A51692)
2015 Ford F-750...
Wearmaster 15-19.5 Tires and Wheels (A51691)
Wearmaster 15-19.5...
2019 PETERBILT 579 TANDEM AXLE SLEEPER (A54313)
2019 PETERBILT 579...
2007 FORD F650 XL SUPER DUTY FUEL & LUBE TRUCK (A51406)
2007 FORD F650 XL...
Hydraulic 50 mm Thumb, NEW never installed (A52384)
Hydraulic 50 mm...
