Backhoe Case backhoe boom won't stay up
   / Case backhoe boom won't stay up #1
TXShelbyman
Case 530
I have a Case 530 loader backhoe. The loader cylinders hemorrhage when the tractor is running. I can raise the loader and turn the tractor off and it doesn't leak down. It will stay up. The backhoe has some leaks too but if I raise the boom it will immediately start dropping back down. I have zero experience on troubleshooting hydraulics. Anyone have a "most likely" guess what is happening? Thanks!
   / Case backhoe boom won't stay up #2
The load check valves in your FEL control valve are bypassing/worn/cocked in the seats or nonexistant...
Some FEL controls do not have "Load Checks" and this would require replacing the control valve with load checks built-in......if the problem just started then you have debris under one of those check valves and it's not seating.....
Hope this helps....:thumbsup:
2012 FORD F-550 SUPER DUTY FLATBED (A52472)
2012 FORD F-550...
Oil Well Pump Jack with Motor (A52377)
Oil Well Pump Jack...
2012 FORD E-350 PASSENGER VAN(INOPERABLE) (A52472)
2012 FORD E-350...
2019 Fontaine Traverse HT T/A 48ft. 41 Ton Hydraulic Dovetail Equipment Trailer (A52377)
2019 Fontaine...
Ford Super Duty FX4 Pickup Truck Bed (A51691)
Ford Super Duty...
GOODYEAR SET OF 9.5-24 AG TIRES (NEW) (A53472)
GOODYEAR SET OF...
