Backhoe Case backhoe boom won't stay up
   / Case backhoe boom won't stay up #1
TXShelbyman
Case 530
I have a Case 530 loader backhoe. The loader cylinders hemorrhage when the tractor is running. I can raise the loader and turn the tractor off and it doesn't leak down. It will stay up. The backhoe has some leaks too but if I raise the boom it will immediately start dropping back down. I have zero experience on troubleshooting hydraulics. Anyone have a "most likely" guess what is happening? Thanks!
   / Case backhoe boom won't stay up #2
The load check valves in your FEL control valve are bypassing/worn/cocked in the seats or nonexistant...
Some FEL controls do not have "Load Checks" and this would require replacing the control valve with load checks built-in......if the problem just started then you have debris under one of those check valves and it's not seating.....
Hope this helps....:thumbsup:
2006 MACK CV (GRANITE) BOB TAIL KILL TRUCK (A52472)
2006 MACK CV...
2008 D&P WELDING 18FT 2000 GAL FUEL TRAILER (A52472)
2008 D&P WELDING...
4"x8' Treated Post, 36 Piece Bundle (A52384)
4"x8' Treated...
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
2022 John Deere RD35F Draper Head (A53342)
2022 John Deere...
2004 PETERBILT 385 (A52472)
2004 PETERBILT 385...
