Case 970 adding loader
/ Case 970 adding loader #1
farm boy00
Veteran Member
Howard City, MI
John Deere M&MT, Case 1030 comfort king, Sears ST16, Craftsmen 6000, homemade articulation mini-loader
Looking for opinions on adding loader and backhoe hydraulics
Case 970 power shift.
Installing a loader and a 3pt backhoe.
Planning on tapping into the pressure line after the pto valve before the 3pt/outlets.
Feed pressure into the loader valve then power beyond back to a quick connect for the backhoe with a power beyond back to the 3pt.
But haven't torn into it fully. Have not seen a great location to run a drain back to the rear end.
Mainly will be used as an oversized loader tractor 75% of the time. Backhoe is just an occasional use so I dont have to rent one when needed. Not worried about it being a 3pt because it won't be used maybe 3-5 times a year after a few projects this spring
2011 Takeuchi TL250 Compact Track Loader Skid Steer (A64553)
2011 Takeuchi...
2022 EZ-GO ELITE...
213085 (A64276)
213085 (A64276)
2006 Freightliner Tuscany 4077 40ft Class A Motorhome (A64557)
2006 Freightliner...
JOHN DEERE 7410 TRACTOR (A64278)
JOHN DEERE 7410...
2013 KENWORTH T800 BOBTAIL VACUUM TRUCK (A65643)
2013 KENWORTH T800...
