case 680ck steering pump
/ case 680ck steering pump #1
Rumber
case 680ck
I'm looking for a power steering pump for a case 680ck c series backhoe.
Or what pump will bolt in? HELP Chuck
/ case 680ck steering pump #2
Case part number is L17373, but Case shows it not available anymore. It does say a pump with the number A139693, had the same flow, but in the description, it says something about the end, the nothing else... Case doesn't even show it, when I did part number search.
Could be a toughy to find, other than a bone yard. Even the rebuild kit doesn't some up anywhere on Google search.
Here is a link to a fellow that has lots of NOS Case parts. He says in his home page, if he doesn't have it, he may be able to find it.
new used parts for Case tractor, backhoe, dozer, machinery & heavy construction equipment.
GOOD NEWS FOR CASE 680ck people with bad power steering pumps. The good people at Hydraulic Pump Store, Gear Pump Solutions Made to Order! can build you a pump to fit your Case 680ck.WOW as you know, used pumps are hard to find.It will bolt in, some rework to the piping and a relieve valve needs to be added.WOW!!!
Concrete Cut Off Saw (A66408)
Concrete Cut Off...
(1) HD 24ft Free Standing Corral Panel (A65579)
(1) HD 24ft Free...
SET OF (4) PORT A POTTIES (A65643)
SET OF (4) PORT A...
(1) HD 24ft Free...
2014 Blu-Jet AT3000 Applicator (A66285)
2014 Blu-Jet...
Wolverine TCR-12-48H Skid Steer Trencher  (A62679)
Wolverine...
