Case 65A - Cab air conditioning
   / Case 65A - Cab air conditioning
Air conditioner still giving out cold air after washing the two outside air filters.
   / Case 65A - Cab air conditioning #12
I don't use the outside air just want to leave
the 100+ air outside the cab. Only used my
a/c unit for about 7 months still works fine.
Years ago my a/c instructor said the you should
run you a/c for 15 to 20 minutes every month
weather you need it or not just to keep the seals
lubricated or don't do it and enjoy the leaks.
willy
I also heard about running the A/C during winter months to keep seals lubricated. I do that about twice a winter for autos and now the tractor. I cannot find the evap pan but there are two hoses over the rear tires that drip water after using the A/C. I expect that means that there is no build-up in the unit. I took the access panel off of the roof of the cab but found nothing to clean. Again all seems to be working as it should right now. I cannot explain why at start-up this spring I was getting hot air at operating RPM's.
   / Case 65A - Cab air conditioning #14
DB Pilot get a parts list for your tractor and you
should be able to find it and it will be easy to
remove or repair and you can see how every
thing goes together.
willy
HYD SPIN SPREADER (A52707)
HYD SPIN SPREADER...
2005 CATERPILLAR 430D BACKHOE (A52707)
2005 CATERPILLAR...
2017 Ford Taurus AWD Sedan (A55853)
2017 Ford Taurus...
2016 Isuzu NRR 20ft Curtain Side Box Truck (A55852)
2016 Isuzu NRR...
Forklift Safety Basket (A56469)
Forklift Safety...
UNUSED FUTURE CAT 301 EXCAVATOR ATTACHMENT SET (A57193)
UNUSED FUTURE CAT...
