Case 580K King Pin replacement cost (?) / advice
   / Case 580K King Pin replacement cost (?) / advice #1
HollowCreek
Case 580K, MF 2244 Dozer, Kubota B Series
Does anyone have experience replacing king pins on a 580K four wheel drive? I noticed too late that my right lower pin was worn and sloppy and found that it has damaged the axle housing it pivots on. I will try to post pictures. The U joints have a lot of play and wear also. My big concern is the axle housing. Local Case dealer thinks (without seeing) it may be able to be welded/ machined by a good fabricator. Axle housing for a similar repair the dealer remembered was $8,000 for the axle housing (part only). King pin and joint replacement job they guesstimate on phone $3-4K. Any advice or experience would be helpful please. Thank you very much.
   / Case 580K King Pin replacement cost (?) / advice #2
where are you located we have done a few king pins over the years we maybe able to help you call us at 800-567-3168
2014 Ford F-150 Ext. Cab 4x4 Pickup Truck (A53422)
2014 Ford F-150...
2024 KMC 7406 (A53084)
2007 Ford Crown Victoria Sedan (A51694)
2007 Ford Crown...
2022 Club Car Tempo Cart (A51694)
2022 Club Car...
2012 Peterbilt 388 Sleeper Truck Tractor (A53117)
2012 Peterbilt 388...
