Case 580K King Pin replacement cost (?) / advice
   / Case 580K King Pin replacement cost (?) / advice #1
HollowCreek
Case 580K, MF 2244 Dozer, Kubota B Series
Does anyone have experience replacing king pins on a 580K four wheel drive? I noticed too late that my right lower pin was worn and sloppy and found that it has damaged the axle housing it pivots on. I will try to post pictures. The U joints have a lot of play and wear also. My big concern is the axle housing. Local Case dealer thinks (without seeing) it may be able to be welded/ machined by a good fabricator. Axle housing for a similar repair the dealer remembered was $8,000 for the axle housing (part only). King pin and joint replacement job they guesstimate on phone $3-4K. Any advice or experience would be helpful please. Thank you very much.
   / Case 580K King Pin replacement cost (?) / advice #2
where are you located we have done a few king pins over the years we maybe able to help you call us at 800-567-3168
2025 K0720 UNUSED Metal Farm Driveway Gate Set (A53117)
2025 K0720 UNUSED...
20X30 ALL STEEL CARPORT (A53843)
20X30 ALL STEEL...
Ammco Brake Machine (A53424)
Ammco Brake...
More info coming soon! (A50322)
More info coming...
PALLET OF CHAINS AND BINDERS (A53843)
PALLET OF CHAINS...
