Case 580CK Steering fluid replacement
   / Case 580CK Steering fluid replacement #1
serf2
Douglassville Pa
Case 580 CK
I just recently bought a Case 580CK and the power steering fluid looks milky as if water had gotten into it. I would like to drain the system and replace the fluid this weekend. Does anyone know what would be the best way to drain the entire system? I've ordered a service manual but do not believe I will have it by the weekend. I appreciate any info anyone may have.
   / Case 580CK Steering fluid replacement #2
I have a 580B - you should be able to disconnect both hoses at the steering cylinder and drain most of the fluid into a bucket -
Then maybe find a rag or other way to seal an air hose around the filler tube on the pump and blow it down (probably messy) -
Then jack the front of the tractor up til the front wheels are clear, put the bucket under the steering cylinder (hoses still off) and manually push the tires to move steering from lock to lock (stroke the cylinder)
- Shouldn't be much left in the system after that... Steve
(INOP) CATERPILLAR 314 EXCAVATOR (A51247)
(INOP) CATERPILLAR...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A53421)
2025 Kivel 48in...
2017 Freightliner M2 106 TMA Attenuator Truck (A52377)
2017 Freightliner...
2001 INTERNATIONAL 2574 6X4 DUMP TRUCK (A51406)
2001 INTERNATIONAL...
2007 Yamaha Rhino 660 (A55218)
2007 Yamaha Rhino...
12in Mini Excavator Tooth Bucket (A52377)
12in Mini...
