I am looking to replace the starter on my Case 580c backhoe. The unit on it is a Delco #1109149. I see in a parts catalog that this machine also came with a Denso starter #028000-5880. The Delco unit should have a 10 tooth gear and the Denso unit has a 13 tooth gear. Same flywheel on engine for both starters. Can I use either starter even though they gave different gears on them without damaging the starter or the flywheel? The ability to use either will help in locating a replacement starter
