Case 580c mystery with shuttle
   / Case 580c mystery with shuttle #1
labiche77
new iberia, la
case 580c
On my 580C I have the dreaded, "reverse no forward" disorder. Ok. So after much research, I was fairly confident that I needed to rebuild my shuttle. check! did that. Put things back together, and guess what.....no change. I also, at the same time, bought another 580c parts tractor. So, I thought maybe I would switch shuttles. So I did. Now I have forward, but no neutral or reverse, and actually, the gears grind if you try to shift into 1 or 2 or 3 or 4th. I have checked the linkage between the cab lever and the shifting mechanism and now I am STUMPED. I thought I was going to save some money not having to go do the local dealer, but now I don't know if I will at all. :(
AC CHARGING MACHINE (A50854)
AC CHARGING...
2025 K0720 UNUSED Metal Farm Driveway Gate Set (A50860)
2025 K0720 UNUSED...
2022 Club Car Tempo Golf Cart (A48082)
2022 Club Car...
2011 Ford Fusion SE Sedan (A48082)
2011 Ford Fusion...
1996 Ford F-350 Mason Dump Truck (A48081)
1996 Ford F-350...
Tubing A500 Grade C 6in. SQ X 1/4in. X 28ft. (A50860)
Tubing A500 Grade...
