CASE 580C Backhoe Fuel/Injector Pump
   / CASE 580C Backhoe Fuel/Injector Pump #1
globalp
qld
Case 580C Backhoe
Just wondering if you can help me with my problem I got a Case 580c,For some reason the engine is full of Diesel,apparantly theres been new pump nd seal put on it.I turned it over this morning and diesel is coming out of the breather on top of the engine,theres no oil on the button,just diesel.
   / CASE 580C Backhoe Fuel/Injector Pump #2
If memory serves me that should be a Roosa-Master pump. There should be two seals on the drive shaft, one to keep the Diesel in the pump and one to keep the oil in the engine. The last time we had a problem we set the engine to top dead center on #1 cyl. and noted the timing mark on the pump. We the pulled the pump and had it services. If the engine stays where you left it reinstalling the pump shouldn't be a problem. If the pump has just been serviced, I'd take it back to them for correction. Don't forget to change out the diesel in the crankcase for motor oil.
Pallet of (8) 10 Lug Misc Wheels (A51573)
Pallet of (8) 10...
2002 Ford F-650 Crew Cab Dump Truck (A48081)
2002 Ford F-650...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
2015 Kubota MX5200F 55HP Loader Utility Tractor (A51691)
2015 Kubota...
2011 International WorkStar 7400 Chassis Truck, VIN # 1HTWGAAR6BJ325793 (A51572)
2011 International...
