CASE 580C Backhoe Fuel/Injector Pump
   / CASE 580C Backhoe Fuel/Injector Pump #1
globalp
qld
Case 580C Backhoe
Just wondering if you can help me with my problem I got a Case 580c,For some reason the engine is full of Diesel,apparantly theres been new pump nd seal put on it.I turned it over this morning and diesel is coming out of the breather on top of the engine,theres no oil on the button,just diesel.
   / CASE 580C Backhoe Fuel/Injector Pump #2
If memory serves me that should be a Roosa-Master pump. There should be two seals on the drive shaft, one to keep the Diesel in the pump and one to keep the oil in the engine. The last time we had a problem we set the engine to top dead center on #1 cyl. and noted the timing mark on the pump. We the pulled the pump and had it services. If the engine stays where you left it reinstalling the pump shouldn't be a problem. If the pump has just been serviced, I'd take it back to them for correction. Don't forget to change out the diesel in the crankcase for motor oil.
2012 KINZE FLAT FOLD ROW MARKERS SET FOR 12 ROW 36/38 STACK FOLD TOOL BAR (A53472)
2012 KINZE FLAT...
Kenworth Tri Axle Dump (A47384)
Kenworth Tri Axle...
2005 TerraGator 8104 (A53472)
2005 TerraGator...
2020 INTERNATIONAL MV607 24FT NON CDL BOX TRUCK (A52576)
2020 INTERNATIONAL...
