Case 580C back tires stopped spinning.
   / Case 580C back tires stopped spinning. #1
Henry3
Case 580C
Hello everybody, I'm pretty new to the tractor world so I have an issue I need advice about. I have a Case 580C that has been working great up until a few weeks ago. I noticed the drive was getting more and more sluggish then I started smelling a differential fluid smell. Soon after that the back tires stopped driving so something seized up or the transaxle fluid is really low. I didn't hear any grinding or other sounds so I'm unsure of what happened. Can anyone steer me in a direction?
   / Case 580C back tires stopped spinning. #2
Are you sure your rear tires are correctly inflated? It is not uncommon for under pressure tractor tires to allow the wheel to turn within the tire beads.
   / Case 580C back tires stopped spinning. #3
Can jack up the rear put transmission in neutral than spin tire listen closly.
   / Case 580C back tires stopped spinning. #4
Is it a power shift transmission? I don’t recall what Case specifically calls it but you shift from F/R without the need to clutch. If so check the fluid level- my 580D/E will stop moving F/R if the hydro level gets low.
   / Case 580C back tires stopped spinning. #5
I believe most of those where a power shuttle or reverser, with a torque converter drive to a manual transmission.
From;574136 Rebuild Kit Shuttle Fits Case 480C, 480D, 480E, 580C, 580D, 580
Or complete with a torque converter; Case Backhoe Power Shuttle Master Rebuild Kit with Torque Converter
2015 Ford F-550 4x4 Knapheide Service Truck (A51692)
2015 Ford F-550...
2014 Jeep Cherokee Latitude SUV (A50324)
2014 Jeep Cherokee...
Ditch Witch 350SX Diesel Ride-On Hydraulic Trencher (A50322)
Ditch Witch 350SX...
2012 Hino 262 Rollback Tow Truck (A50323)
2012 Hino 262...
2014 Deere 304K (A50120)
2014 Deere 304K...
UNVERFERTH 330 - 19-INCH EXTENSION KIT FOR RIP-STRIP TOOLBAR PART # 63186G (A52748)
UNVERFERTH 330 -...
