CASE 580B Tachometer
   / CASE 580B Tachometer #1
azrancher
Hereford, AZ
MF30, Case 580B, Case 550E Cat RD6
1973 580B, I've had this Backhoe for about 20 years so I know how fast it is running just by sound, however the tachometer has now decided to read excessively high, and I think it's a mechanical tach, so I don't understand what is going on, and it varies, sometimes it appears to be reading correct, and other times it's red lined. Anybody have any insight on what is going on?
Rancher
   / CASE 580B Tachometer #2
Sometimes they get crudded up or rusty - you might try taking the tach cable loose on both ends, blowing it out with compressed air, and working some graphite speedometer cable lube down into the outer sleeve - that's basically what it is, is a speedo cable... Steve
(If the cable binds up for any of those reasons, the uneven jerking when it breaks loose will cause erroneous readings. Try not to break any part of it though - they are NOT cheap anymore...
2006 Poly-Coat Tanker Trailer (TITLE) (A50774)
2006 Poly-Coat...
2015 Ford F-450 Crew Cab Knapheide Service Truck (A50323)
2015 Ford F-450...
Countyline 3pt Fertilizer Spreader (A50121)
Countyline 3pt...
2018 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A52576)
2018 FREIGHTLINER...
2016 Kubota RTV-X900 4x4 Utility Cart (A51691)
2016 Kubota...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2013 Ford F-150...
