Case 580b shuttle/shift
/ Case 580b shuttle/shift #1
gryan
Case 580b shuttleshift
Low power when in gear,foward and rev......rpm @1800+, trans pump gauge in the green, changed fluid and trans filter..could a cloged pickup tube cause this ?? Still scratching my head....Any help before I contemplate the clutches?
/ Case 580b shuttle/shift #2
Can't really help much but when i was looking at/researching a 580B i remember hearing that a common problem was a clogged pickup screen. If there wasn't much damage done i think a hole could be drilled under the screen to clean it and then tap the hole and install a pipe plug.
Someone more knowledgeable will come along and help you out.
2016 Ford Explorer AWD SUV (A61569)
2016 Ford Explorer...
CASE INTERNATIONAL 5240 TRACTOR (A63291)
CASE INTERNATIONAL...
Landhonor Livestock Chute (A66408)
Landhonor...
2018 FORD F-150 (A65643)
2018 FORD F-150...
New/Unused 3 Point Hitch with Ball/Flat Hitch (A65583)
New/Unused 3 Point...
(1) 30 Yard Roll Off Dumpster (A65579)
(1) 30 Yard Roll...
