Case 580 SE coolant problem
/ Case 580 SE coolant problem #1
Tractorguy24
Bronze Member
BC, Canada
If I look into the radiator on my 580 backhoe, the coolant is all the way to the top (when engine is cold). Sometimes it also spews it out.
If I look into the reservoir its below the add mark. Any ideas on what may be causing this? The OM only tells me what to do when the radiator is low and the reservoir is full.
Thanks!
/ Case 580 SE coolant problem #2
It should only be able to spew it out through the hose to the reservoir. Anywhere else and the hose is either plugged or something else is letting it out, like a bad cap gasket.
2020 John Deere 6120M (A62180)
2020 John Deere...
(12) 3" Rachet Straps & (1) 3" Rachet (A64127)
(12) 3" Rachet...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
Chandler PT Stainless Steel Spreader (A64126)
Chandler PT...
2022 New Holland Boomer 45 (A64126)
2022 New Holland...
Pallet of Four Pivot Wheels & Tires (A62177)
Pallet of Four...
