case 530 pto slipping
   / case 530 pto slipping #1
Yohiker49
Louisville, Kentucky
Case 530 / kubota L4400
I have a Case 530 model 541 the pto hand clutch lever is middle ways in the tractor body in front of your left knee if you was setting on the tractor. The clutch itself is inside the main body. How can I adjust it? Most of the other 530's the pto clutch is behind the rear end of the tractor where the pto implement hook up is.
There is nothing to it. Step 1 remove the 3 speed shifter (triple range) you will see the clutch right there inside the tractor main body. Step 2 there is 2 fancy pins sticking out of the clutch they look like chess pons one will be in the other will be sticking out a little bit.( it is spring loaded) Step 3 pull out the one that is in and turn the clutch clock wise by hand until you hear the other pin click in, that part of the clutch is threaded. Keep on doing this until the hand lever reaches about 60 lbs. pull to engage and disengage it. One pin will be in and the other will be out, always. Works like a charm.
1999 Ford RV , VIN # 3FCMF53S2XJA29020 (A51572)
1999 Ford RV , VIN...
2016 KENWORTH T680 TANDEM AXLE MID ROOF SLEEPER TRUCK (A52576)
2016 KENWORTH T680...
2011 Kubota R520S 4WD Articulated Wheel Loader (A51691)
2011 Kubota R520S...
Kenworth Tri Axle Dump (A47384)
Kenworth Tri Axle...
2018 Club Car Carryall 500 Electric Utility Cart (A51691)
2018 Club Car...
2007 Ford Taurus SE Sedan (A51694)
2007 Ford Taurus...
