case 530 pto slipping
   / case 530 pto slipping #1
Yohiker49
Louisville, Kentucky
Case 530 / kubota L4400
I have a Case 530 model 541 the pto hand clutch lever is middle ways in the tractor body in front of your left knee if you was setting on the tractor. The clutch itself is inside the main body. How can I adjust it? Most of the other 530's the pto clutch is behind the rear end of the tractor where the pto implement hook up is.
There is nothing to it. Step 1 remove the 3 speed shifter (triple range) you will see the clutch right there inside the tractor main body. Step 2 there is 2 fancy pins sticking out of the clutch they look like chess pons one will be in the other will be sticking out a little bit.( it is spring loaded) Step 3 pull out the one that is in and turn the clutch clock wise by hand until you hear the other pin click in, that part of the clutch is threaded. Keep on doing this until the hand lever reaches about 60 lbs. pull to engage and disengage it. One pin will be in and the other will be out, always. Works like a charm.
2002 FREIGHTLINER FL70 DUMP TRUCK (A51406)
2002 FREIGHTLINER...
2013 Ford Edge SEL SUV (A51694)
2013 Ford Edge SEL...
JOHN DEERE 4730 LOT NUMBER 268 (A53084)
JOHN DEERE 4730...
JOHN DEERE 1705/6700 LOT NUMBER 20 (A53084)
JOHN DEERE...
Billy Goat Blower Paint Dryer, 6.5 Briggs (A52384)
Billy Goat Blower...
2024 KMC 7406 (A53084)
