Case 485 Question on buying?
   / Case 485 Question on buying? #1
saltbranch
Going to look at a 2wd w/ FEL 1260 hrs, any known problems to look out for?
Thx
   / Case 485 Question on buying? #2
Good tractors! Brakes might bleed down as the worst problem from that age range.
   / Case 485 Question on buying? #3
If the park brake is important to you, make sure it works. It is a band internal to the transmission and is expensive to repair, I understand. They are often left engaged and driven. It also puts chunks of the brake material into the hydraulic system. There are very good tractors and I especially appreciate the synchronized speed gears.
Thanks for the replies, we bought it Friday and played all weekend on it. Everything works great, has 1280 hrs on it.
Thanks for the heads up on the parking brake.
Honda utv cart (A56859)
Honda utv cart...
1992 DFI PULL SPREADER (A57192)
1992 DFI PULL...
2008 TEXAS BRAGG 20 UTILITY TRAILER (A58214)
2008 TEXAS BRAGG...
2007 Amkus Rescue System (A56857)
2007 Amkus Rescue...
John Deere Gator (A53317)
John Deere Gator...
2015 Freightliner Derrick Digger Truck (A55973)
2015 Freightliner...
