Oil & Fuel Case 485 fuel priming procedure help....
   / Case 485 fuel priming procedure help.... #1
ChadRenfro
I need to bleed the air out of my fuel system on my case 485. I have no idea what the proper process is for this. I have a duel fuel filter system setup. Any help would be greatly appreciated.
   / Case 485 fuel priming procedure help.... #2
I have the 484. If it’s like mine, there should be a screw on top of the filter housing. Take that screw out of the first filter that is in line with the tank and let it bleed all the air out. Repeat for the next filter. If you have changed filters, the best way to avoid this is to fill the filters with fuel first. That’s what I do and both tractors (484, 685) fire right up with no problems.
   / Case 485 fuel priming procedure help.... #3
I have a 385 and have had success bleeding air first by loosening the screw on top of the filter housing on the right side of the tractor until no air is in the fuel. Then repeat on the housing on the left. The owners' manual says if the engine still runs rough to bleed remaining air by momentarily loosening the injector lines starting at cylinder #1. My engine always picks up the fuel without bleeding the injector lines.
BUNDLE OF USED GALVANIZED CORRUGATED METAL SHEETS (A51244)
BUNDLE OF USED...
Agway Bale Accumulator (A50515)
Agway Bale...
3 pt Rolling Basket & Harrow (A50514)
3 pt Rolling...
2021 Caterpillar 304E2 Mini Excavator (A50322)
2021 Caterpillar...
2014 CATERPILLAR CB54 XW SMOOTH DBL DRUM ROLLER (A51242)
2014 CATERPILLAR...
2011 Nissan Rogue SUV (A50324)
2011 Nissan Rogue...
