case 480LL running problem
/ case 480LL running problem #1
BBQJOE
Wikieup
case 480 LL
Hi all! First post here. I'm baffled.
I have a fair amount of diesel experience, but I'm no diesel mechanic.
I have an older case 480 LL. It starts right up. Runs for about a minute at idle, not so long at full throttle, then dies.
If I let it sit a minute or so, it starts right back up, then dies again in a minute or so.
I suspected fuel filters, and replaced them both. Problem still exists.
Air filter dirty, but I've seen worse. Tried running it without the filter, same result.
Engine has oil, and water. Battery is good.
This appears to be gravity fed, and the return goes straight to the bottom of the tank.
I anxiously await your thoughts.
/ case 480LL running problem #2
Blocked outlet from tank ?
Blocked screen in liftpump ?
Blocked fuellines ?
Blocked screen at inlet to injecorpump ?
/ case 480LL running problem #3
Blocked return line..??
16in. Bucket with Teeth Excavator Attachment (A64194)
16in. Bucket with...
2026 SDLANCH SDLC2020 High-End Carport (A64194)
2026 SDLANCH...
Kivel 48in Forks and Frame Skid Steer Attachment (A64553)
Kivel 48in Forks...
2015 Nissan Frontier Ext. Cab Pickup Truck (A64556)
2015 Nissan...
2012 Ford E-450 Sewer Viewer Van (A64556)
2012 Ford E-450...
Metaltech Climb and Go (A64553)
Metaltech Climb...
