Case 480B Hydraulic Filter
/ Case 480B Hydraulic Filter #1
Keithw
Naples, fl
Case 480B
Hello everyone , just bought an old Case 480B (craigslist special) for use around the property. I am in the process of giving it some TLC and ran into a problem. I wanted to change the hydraulic filter and pulled off the canister right in front of the loader controls and found no filter at all. Does anyone know what part number (Wix, Fram or other I can cross reference) fits in that canister? The other weird thing is the canister on mine faces or hangs down, in the manual, it is shown to face up...does it matter?
BTW, I cant read the serial number on the plate but this tractor has the primary and secondary fuel filters so I believe it is After Engine Ser# 2718490
For those needing the answer...it appears it is: Wix 51760 or Napa 1760 Hydraulic Filters
/ Case 480B Hydraulic Filter #3
Hi Keith, I'm currently looking at a 480B cl special myself for around the house. Long shot if you answer, but how did that unit work out for you? Any major issues? Thanks for posting the filter numbers in case I need them. I will do the same thing you are doing, give it a little tlc so it will return the favor lol
1996 John Deere 7700 (A64911)
1996 John Deere...
2000 KENWORTH T800 CRANE TRUCK (A67714)
2000 KENWORTH T800...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A63569)
2020 TROXELL...
2023 JCB S3246E ELECTIC SCISSOR LIFT (A63276)
2023 JCB S3246E...
2002 SUPERLINE DO20T242LP T/A 24FT TRAILER (A66091)
2002 SUPERLINE...
2006 WINSTON AP22024AL-DC T/A 24FT TRAILER (A66091)
2006 WINSTON...
