Case 450 want move after start
   / Case 450 want move after start #1
willjr
batesville ms
case 450 dozer
I have a case 450 dozer that will not move for 20 or maybe 30 minutes after cranking. Has 25 #'s torque converter pressure and between 250 and 300 #'s pressure at transmission . After running a while it gradually moves and gets up to a acceptable pace . Does as well as it has since i have owned it ? Any suggestions on what could be causing this cold no go ?
   / Case 450 want move after start #2
Improper oil in the transmission? Sounds like too heavy of a weight of oil, but thins enough to drive when warmed up a bit. Should be Case TCH, or equivalent. Have you changed the trans oil since you've had it..??
I did have a line break and put regular tractor Hydraulic oil in it .
   / Case 450 want move after start #4
This problem usually indicates that the transmission pump is sucking air. If all the suction hoses are in good order & clamps are tight ( no oil leaks while parked?) the problem could be the pump itself ( though unlikely it's the pump -with a transmission pressure of c.290psi indicates the suction screen is not blocked & the charge pump is operating fine) -The trans can use any good trans/converter/hyd oil
Ok anyone know the best way to drain all of the mixed ....bad fluid out ?
Hyster H90FT 8,000lb Diesel Forklift (A55973)
Hyster H90FT...
Toyota 7FGU35 8,000lb. Propane Forklift (A55973)
Toyota 7FGU35...
John Deere 4600 (A53317)
John Deere 4600...
2015 Ford Taurus Sedan (A56859)
2015 Ford Taurus...
RING 2 STARTS HERE @ 9:15 AM (A58375)
RING 2 STARTS HERE...
2015 Peterbilt 567 T/A Day Cab Truck Tractor (A55973)
2015 Peterbilt 567...
