Case 450 want move after start
   / Case 450 want move after start #1
willjr
batesville ms
case 450 dozer
I have a case 450 dozer that will not move for 20 or maybe 30 minutes after cranking. Has 25 #'s torque converter pressure and between 250 and 300 #'s pressure at transmission . After running a while it gradually moves and gets up to a acceptable pace . Does as well as it has since i have owned it ? Any suggestions on what could be causing this cold no go ?
   / Case 450 want move after start #2
Improper oil in the transmission? Sounds like too heavy of a weight of oil, but thins enough to drive when warmed up a bit. Should be Case TCH, or equivalent. Have you changed the trans oil since you've had it..??
I did have a line break and put regular tractor Hydraulic oil in it .
   / Case 450 want move after start #4
This problem usually indicates that the transmission pump is sucking air. If all the suction hoses are in good order & clamps are tight ( no oil leaks while parked?) the problem could be the pump itself ( though unlikely it's the pump -with a transmission pressure of c.290psi indicates the suction screen is not blocked & the charge pump is operating fine) -The trans can use any good trans/converter/hyd oil
Ok anyone know the best way to drain all of the mixed ....bad fluid out ?
(1) HD 24ft Free Standing Corral Panel with 7ft Gate (A51573)
(1) HD 24ft Free...
2016 Ford F-550 Palfinger PSC3216 4,000LB 2 Ton Crane Service Truck (A51692)
2016 Ford F-550...
2012 Ford F-350 Mechanics Service Truck (A51692)
2012 Ford F-350...
INOP/NON-RUNNING 1999 International F-2574 Fuel Lube Truck, VIN # 1HTGGATT4XH682675 (A51572)
INOP/NON-RUNNING...
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
2025 New/Unused Wolverine Pallet Fork Extensions (A51573)
2025 New/Unused...
