Case 450 Dozer Battery
   / Case 450 Dozer Battery #1
skyking002
Trying to resurrect my neighbors dozer. Serial number 3059725. I don’t have the manuals and the battery has been removed. My research has conflicting information on the proper battery. Some says 31 group and others 4D. Anyone have the proper battery information or service manual? Thanks!
   / Case 450 Dozer Battery #2
Can't help on most of it, but this is the best chart I've found for comparing battery box size to figure out what is going to fit:
Starting with the battery box still leaves a lot of decisions. There are several different terminal types and polarity configs - - not to mention Wet, AGM, and Sealed types. Plus starting, deep-cycle, and dual purpose.
ALL OF THEM WILL WORK. Not all will start an old diesel on a cold morning.....
On old equipment I usually just get the largest, heaviest, highest CCA in a 12 volt AG starting type battery that will fit the battery box and the cables. Odyssey brand AGM batteries are top choices for fire and police depts when budget allows. You can buy them online from a California shipper.
rScotty
Thanks for the great information. You have at least given me a starting point.
   / Case 450 Dozer Battery #4
Good luck with it. My buddy has done a couple of older Deere dozers and one road grader. I'm always surprised at how well those old machines respond to what is really just fixing maintenance problems, bearings, hoses and such. They get parked for something simple and then nobody ever gets back to them.
On most of them the major systems are still fine.
Re: batteries, some of the old ones were set up to use parallel 12 volt batteries for more cranking amps
I used to do that, but in the last 5 years or so I can't seem to get two batteries that are electrically similar enough so that one doesn't drag the other down. That's even when buying identicals from the factory.
So I've been paying more attention to pre-heat and just using a single real good battery. No more duals.
That works surprisingly well, and sure is simpler. On my old 310 with dual 12s I alternate the batteries instead of running them in parallel. Seems to be just as good.
rScotty
   / Case 450 Dozer Battery #5
rScotty
Has to be sure not 24 volt also.
I just rebuilt the starter. Hoping to get it on this weekend. It’s a 12V system. The gentleman who owned it just parked it one day. His health prevented him from tinkering with all of his equipment. Trying to help his widow. I have a local place that rebuilds batteries. I can get a rebuilt 4D group battery for the same price as a new 31 Group. I figure it will take some cranking to get the engine running after many years of sitting.
   / Case 450 Dozer Battery #7
When I was a kid in rural Eastern Oklahoma/Arkansas my dad taught me how to rebuild batteries. It used to be a common rural mechanic garage skill.
There is no reason at all not to use a good rebuilt battery. Ask for one that has good pure lead plates - still thick and not warped or cracked. What you really want is a good battery that failed because the sulphation built up until it shorted the bottom of the plates. That is a common failure mode. When rebuilt, those are every bit as good as new. To keep them that way, set the battery on a rubber pad or spacers to reduce the vibration, check the Sp. Grav. every summer, and only add distilled water.
Can't wait to hear it running.
luck, rScotty
Great info! It always amazes me how much how to knowledge has been lost. Wish I had half the knowledge of the previous generations.
Perfect, Thanks
2012 JACK CO 130 BBL VACUUM TRAILER (A45046)
2012 JACK CO 130...
2020 John Deere 6105E 2wd cab tractor (A44789)
2020 John Deere...
2015 POLARIS RANGER (A45046)
2015 POLARIS...
2012 KENWORTH T800 (INOPERABLE) (A45333)
2012 KENWORTH T800...
TD WILLIAMS NATURAL GAS TAPPING EQUIPMENT (A45333)
TD WILLIAMS...
2017 INTERNATIONAL PROSTAR+ (A45046)
2017 INTERNATIONAL...
