Case 45 hydratatic
   / Case 45 hydratatic #1
Shannon14
Walhunding, Ohio
Farmall 45d
Need help. I have a case 45d with hydrostatic drive. Recently the tractor started to bog under load. It will idle with no problem but as soon as I put it in hi or low range or try to move it will stall. Issue is very inconsistent but is getting worse. Any suggestions would be greatly appreciated.
Have you checked the fuel filter?
I did. I replaced the fuel filter and did an oil and hydro change with all filters. Turned out to be a clogged gas cap. Cleaned out all vents and ran it for an hour with no problems! Thanks for the suggestion
   / Case 45 hydratatic #4
Had a friend that had a similar problem with his 500 hp Case/IH Steiger. Kept clogging the fuel tank vent. Took a large pair of channel lock pliers to get the cap off and when we did, it sounded like it was going to suck in anything within a 300' radius. HAHA Glad you got it fixed.
Cub Cadet Kohler mower 7000 series (A50324)
Cub Cadet Kohler...
SHOULE PWD-10 LOT NUMBER 133 (A53084)
SHOULE PWD-10 LOT...
JOHN DEERE S780 LOT NUMBER 36 (A53084)
JOHN DEERE S780...
LEONARD 16 ENCLOSED TRAILER (A52472)
LEONARD 16...
2014 PETERBILT 367 (A52472)
2014 PETERBILT 367...
2015 TEXAS PRIDE  GOOSENECK (A52472)
2015 TEXAS PRIDE...
