CASE 446 GARDEN TRACTOR
/ CASE 446 GARDEN TRACTOR #1
yooperdave
Marinette, WI
Tool Cat 5600, LS XJ2025H, Branson 4215HC
Does anyone know anything about used Case 446 garden tractors (or similar)?
I think it has a 16 hp engine. It has very large rear wheels.
I thought I heard that Case made a solid unit.
I am trying to get the year and how many hours are on it. Condition seems pretty good.
Thanks
Yooper Dave
/ CASE 446 GARDEN TRACTOR #3
These are VERY well built tractors, capable of matching almost anything built in their class from the same era. The company is still operating as Ingersol and recently was bought out and relocated to Maine. My personal preference would be to have a Kohler or Briggs engine instead of the Onan because of parts cost and availability, so check what brand engine it has. The only negative thing I can think of is that they might not be considered as ergonomically friendly as todays machines, but that wouldn't stop me if it's available at a decent price in decent condition. Most attachments are hydraulically driven and were also VERY well built. As a true heavy duty garden tractor, this would be a great tilling and /or snow removal machine. I don't know what your primary use would be, but it can do a lot more than just cut grass.
/ CASE 446 GARDEN TRACTOR #5
Looks like the Case has been taken care of...than most I seen on ebay.
I would take closer look and throw least one bid in,that's if the case will fit your needs.
/ CASE 446 GARDEN TRACTOR #6
It's at a fair price right now. The tractor looks to have been very well cared for, grill doesn't look dented, paint looks pretty good. The colors indicated it's from the early to mid 1970's. Sure would be nice to see if it has a cat "O" 3 point on the rear, or the rear PTO, or any other optional equipment.
/ CASE 446 GARDEN TRACTOR #7
Well, I have poked around the 'net a little more and see that there are a couple on Craig's list that are in the same price range, similar condition, but offer more attachments. Ebay units are a little more money. So I stand by my statement that it's a fair price, not a great bargain, not a rip off based on it running as good as it looks. Sure would prefer the Kohler or Briggs motor though.
/ CASE 446 GARDEN TRACTOR #8
I worked at Case and watched these models being used for garbage bin towing, fogging for mosquitoes, mowing, snow blowing, and just plain being abused to the MAX!!! I have seen them continually run foward and then slammed into reverse and vice versa popping wheelies, used as parts chasers and anything else you could think of using them for and they took it, every bit of it and kept on running. They have an almost unbreakable hydro system. I had one of them and it did a great job mowing. I had one of the heavy duty front end loader models with tiller and it was also a very tough little tractor. It would lift almost as much as my 2015 Mahindra, amazingly tough. Only problem I had was the tiller not having a depth stop and it would jerk into the ground and stop if you weren't careful. I also sold one like in the pic recently for $1500 with mower and snow blade. If it is in as good shape as it appears, you won't go wrong..John
/ CASE 446 GARDEN TRACTOR #9
For $905.00, somebody just got a nice deal on that one if the Onan Performer is in decent shape. Onan made some of the smoothest running aluminum blocked air cooled engines I have ever come across, the oldie Onans are a thrill to own, unfortunately they are no longer made or supported by Linamar or Kubota who bought that sector of Onan out. So if you have an old GT with Onan power you either baby it, or retrofit a different engine to it when the time comes if you don't have a stockpile of replacement parts. -Fordlords-
/ CASE 446 GARDEN TRACTOR #10
These tractors are tough....real tough. My neighbor has a 98 model and blow my 300+ foot driveway with 18 inches of snow in 15 minutes.
I personal know a dealer that sells and repairs these. He worked for a logging equipment company locally that builds lifting booms that lifts the logs onto the trucks. The same pump that powers the Case tractors is the same pump that powers the booms that lift uncut logs!!! Yes, Case tractors will smoke, spin tires, backwards or make you superman if slammed into reverse when going forward. It hurts!! :D
I looked at these before I bought my JD 2210, but the Deere won due to newer and bucket. 10 months later I picked up a awesome 79 Case 446, 20 Hp Onan with deck and snowcaster aka blower for much less than a 15 year old, well used PTO snowblower for my Deere!!!! I'm a happy camper now!!!!
/ CASE 446 GARDEN TRACTOR #11
The tires on mine are 16" x 8" wide. not easy to find the big lug tires unless you go to miller.com which has a good selection. I'm still working on getting parts and building it up for use.
Anyone have a 3 point hitch they want to sell?
/ CASE 446 GARDEN TRACTOR #12
We used a 446 on our dairy farm for 14 or 15 years, scraping freestall barns, the barnyard, feeding heifers, rototilling gardens for ourself and others, plowing snow, you name it. VERY tough tractor! Never really had any problems with it.
/ CASE 446 GARDEN TRACTOR #13
i bought a case 446 about month ago and it need some work. i got it fix up and i am having great time with it. the first thing i did as soon as i got it going was try the tiller out on the ground.wow it did a great job. i also got a old 444 in the yard and it needs a lot more work on it to be done to it. i really did not know that much about them. i have to get the pto clutch yet since who ever work on it before me screw it up by putting it together wrong. i live western canada where parts need to be got up from across the boarder.
/ CASE 446 GARDEN TRACTOR #14
Hey Im new to the group I just traded for a 78 Case 446 with a 48" deck a snow blade an a tiller also a somewhat parts tractor of the same ...
Im wanting somethin bigger than my hubbys JD 300 on my small horse farm for stalls an arena work etc...I really wanted somethin with a bucket but I used to own a large Ingesoll an that lil tractor was tough does anyone know if I can put a bucket on this tractor dont know a whole lot about it other than its a project it doesnt run..I hope Im not makin a bad trade any suggestions would help thanks Cwgrl..
/ CASE 446 GARDEN TRACTOR #15
I would suggest that you look for a 400 Series John Deere that is already fitted with a front end loader. Trying to find just the loader itself for a Case 446 will not be easy and then there is the issue of powering that loader. Now if all you want to do is to lift a bucket of material off the ground and transport it elsewhere to dump it, then you might consider a Johnny Bucket Jr. The good part is that it is designed to mount onto the Case Snap Fast pins on the front of the tractor just like the snow blade does. Here is the link. There are also videos on Youtube that show it in operation.
Case Ingorsol Johnny Bucket Jr. Page
2017 P.J. Deck Over Trailer, VIN # 4P5F82021H1265098 (A65563)
2017 P.J. Deck...
1991 CAT 3406 Generator Set 400KVA/320KW, 480V 3-phase, 60Hz, Industrial Standby (A63689)
1991 CAT 3406...
2015 Nissan Altima Sedan (A64557)
2015 Nissan Altima...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A63569)
2020 TROXELL...
New/Unused Wolverine 3 Point Hitch Attachment (A65583)
New/Unused...
2013 Ford Taurus Sedan (A64557)
2013 Ford Taurus...
