Case 444 fuel pump
   / Case 444 fuel pump #1
toad430
Dunlap,Il
case 444 and 646
I have a case 444 and lost fuel pressure. I replaced the pump but can't get it to prime and pump. Is there a trick to priming a gas fuel pump on a Kolher 14 hp engine in a old case 444?
   / Case 444 fuel pump #2
No trick to it. Is the pumps lever riding on the cam properly?
Can you get fuel through the line to the pump? Some gas tanks have a screen filter inside the tank, sometimes attached to the petcock.
   / Case 444 fuel pump #3
If you pour a little gasoline directly into the carburetor, the engine should start and the pump will kick in.
   / Case 444 fuel pump #4
The K321 engine has a mechanical pump that shouldn't need priming. I've rebuilt a couple of these motors including replacing pumps and have never had to prime one.
I'd check fuel lines for a good flow and also for dry rot/cracks.
Here's a site with tons of info on the Kohler engine, the page linked has info on your fuel pump Information about the Kohler Carburetor, Various Fuels and Fuel Systems
I recently replaced the fuel lines and there is no petcock. when I dip the fuel line lower than the tank no fuel comes out so tomorrow I will disassemble everything and check for a pinch or blockage. Thank you
Thank you for all of the ideas. I will start tomorrow working my way through them and will keep you all posted
American G-Model Pump Jack (A53472)
American G-Model...
UNUSED FUTURE FT-XJ7T 7 TON 46" HYD THUMB CLAMP (A51248)
UNUSED FUTURE...
2019 KUBOTA KX057-4 EXCAVATOR (A51246)
2019 KUBOTA...
(APPROX 24) 2" X 6" X 60" CHANNEL IRON (A51247)
(APPROX 24) 2" X...
2011 Manac 36245B30 43ft T/A Walking Floor Trailer (A50322)
2011 Manac...
2017 John Deere HPX615E Gator 4x4 Utility Cart (A51691)
2017 John Deere...
