case 444 bogs down
   / case 444 bogs down #1
Oboy5
allendale mich
1976 case 444 14hp
i have a case 444 it runs good for 5 to 10 min with the mower on and then it boggs down and will all most quit. I turn off the mower and throttle it down it will run fine throttle it back up still running good turn on the mower and it boggs down. i can run the mower at a idle. and if i throttle it up to fast it will start running rough. it"s running hot to. is this a carb issue
   / case 444 bogs down #2
sounds like it to me , clean the main jet , the emulsion tube ( under the mainjet ) and check the float level.a plugged mainjet will make an engine lean out and if not corrected will melt pistons
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A53473)
PENDING SELLER...
2023 BOBCAT T62 COMPACT SKID STEER TRACK LOADER (A53473)
2023 BOBCAT T62...
2008 FORD F450 SERVICE TRUCK (A54607)
2008 FORD F450...
2024 BCL Fabrication Landscape Dump Trailer - Heavy-Duty Utility Trailer for Mulch Debris Hauling (A53473)
2024 BCL...
MISC WRENCHES (A53843)
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
