case 430
/ case 430 #1
2diamondfarm
West Michigan
TYM 574, Deere 4410, Gehl 353 Mini Ex
I am in need of the power steering cylinder for a Case 430 industrial loader tractor .
it seems they were only made for a few years any leads would be helpful.
/ case 430 #2
Since you said "cylinder", I am assuming it only has one steering cylinder. The CK (Construction King) model has two.
If it only has one, then it should be a 430 utility/ag model. Now comes the fun part... You need to check and see if it is the heavy duty axle. Easiest to go to Case/IH parts search, Case IH Agriculture & Farm Equipment and look real close... There is a difference in the front spindles, in the way they are shaped. You will also need to find your tractors serial number.
Or..., if you can find the part # on the cylinder. Probably on the part where the lines go in. Case/IH shows the cylinder # as G14451. for on the HD axle.
Then they show a 430 with loader, prior to SN 82628000. This cylinder # is G45312.
If by chance it is the G14451, these were also used on the 530's, w/HD front axle...
The good news.... Unless it is T-totally trashed, and just leaking... Seals & O-rings are still available to rebuild them.
Actually, the G14451 is still available, new through Case/IH. The bad news... $2100.00+
Depending on how quick you need it, I saw several over the past year on ebay. Most could be bought for $150.00, or less. But you're getting a pig in a poke...
Or, you can follow this link to Tractorhouse Used Tractors For Sale at TractorHouse.com: John Deere Tractors, used farm tractors and farm equipment, tractors for sale, Case IH, New Holland, Agco, Kubota In the top ledt menu, there is a place there to place a free "want to buy" ad. It goes to numerous salvage dealers all over the U.S. I've found several hard to find parts using this feature. I do believe you need to register with them to do this. No charge, it is free. Most will contact you within 48 hours, if thye have the part.
I tried searching for a 430, and 530 in salvage yards, but none to be found...
Hope this wasn't too long, and confusing...
2017 Ford F-250 Single Cab Pickup Truck (A61573)
2017 Ford F-250...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2005 Komatsu PC 200 LC (A60462)
2005 Komatsu PC...
2016 CASE TR340 Track Loader (A63111)
2016 CASE TR340...
2007 International 7500 sba Flatbed 6x6 Truck (A62679)
2007 International...
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A59230)
2018 Ford F-150...
