case 4210 auxilary hydraulics failure
   / case 4210 auxilary hydraulics failure #1
robbb
worcester UK
massey 3095 case 4210 massey ferguson 3070
Hi recentley rebuilt a case 4210 and put new gears in gear box (3 gears gone bang oh dear ) haveing put cab back on and done a lot of spanner work etc everthing seems to work ok but I am haveing trouble getting auxilary hydraulics to work ,seems perhaps not enough oil kicking through . Levers seem to be operating valves ok any ideas gratefully recieved Rob.
   / case 4210 auxilary hydraulics failure #2
Make yourself a hyd test set and take some pressure readings.
Check your pump to see if it is operating.
Remove a hyd hose and place in bucket and see if you have any flow.
Thanks , I will definately have to get a tester I think it will be very useful on our farm another member advised me to get one for another problem may speak to you again when I get time to do the job Rob.
   / case 4210 auxilary hydraulics failure #4
Hydraulics:
Type: open center
Capacity: 9 gal [34.1 L] (2WD)
9.7 gal [36.7 L] (cab)
Pressure: 2500 psi [172.4 bar]
Valves: 0 to 3
Total flow: 16.1 gpm [60.9 lpm]
18.4 gpm [69.6 lpm] (optional)
TractorData.com CaseIH 4210 tractor information
4 1/2 150G DRILL STEM 358 JOINTS (A50854)
4 1/2 150G DRILL...
2011 TROXELL 140BBL TRIAXLE VACUUM TRAILER (A50854)
2011 TROXELL...
Trailer Axles (A50860)
Gravely Pro-Turn 152 Zero Turn Mower (A50860)
Gravely Pro-Turn...
2012 BIG TEX PIPE TRAILER (A50854)
2012 BIG TEX PIPE...
2009 IC Corporation PB105 School Bus (A48081)
2009 IC...
