Comparison Case 4 Stick Backhoe Controls - How are they?
   / Case 4 Stick Backhoe Controls - How are they? #11
Yes, but I think the levers might fry my brain:D
Does anyone know how much time and money it would take if I decided I wanted to mess around and switch the controls to two stick. Not necessary but if I was looking for a project.
More than it is worth, why not rent a 4 stick Case for a weekend and give it a day or two to see if you can deal with it? That would be alot cheaper than buying something you are unhappy with.
It has been maybe five years since I ran a Case 4 stick but I wouldn't hesitate to jump on one if I needed to. As someone else mentioned might take a little time to make the brain adjustments.
   / Case 4 Stick Backhoe Controls - How are they? #12
Anyone happen to know how many horsepower the 590 Turbo is, I've seen different ratings out there and wondering if any of you knew.
Go to the Casece.com website and look around.
   / Case 4 Stick Backhoe Controls - How are they? #13
. . . to look at a Case. . .
The only problem is my brain is wired to the two stick controls. Tried the 4 stick once and it was like a 5 year old was running the hoe. . .
I'm a bit confused here, :confused: but I had a 1984 580 Super E, and it was a 3 stick with foot pedals for the swing. I've never seen a 4 stick Case. The old Fords were 4 stick, but I don't believe the Case was. (at least not a mid-'90's model)
I think that Taylortractornut is correct. The "fourth" stick is for the extendahoe, IIRC.
As far as the 3 stick w/foot swing Case set-up, I can operate one as well as the 2 stick controls. (if not a little better) But, then again, I have a lot of hours on them.
   / Case 4 Stick Backhoe Controls - How are they? #14
I'm in the same camp as Bigfoot. I've run most systems and once comfortable with the controls productivity is about the same.
   / Case 4 Stick Backhoe Controls - How are they? #15
Case can be ordered with 4 stick controls without a foot swing I have a friend thats grew up on the old Ford Sherman controls. He ordered his new with a 4 stick sherman I cant hit the ground with it well I can hit the ground thats about it.
The foot swing pretty nice. because the when you push one down the other rises a bit and it balances you and its less tiring on the hands. My old Ford has L shaped handles and Take alot of hand spans to work it. Case levers are closer and the foot swing eases a set of fingers lol. The older foot swings are more comfortable to run to me than the same age of 2 stick cases with the tapered levers.
If you get a Case theres a trick to locking the boom up in transport position. A few folks here run them and dont lock the hoe up. Just fold the stick and bucket up and center the boom on the swing pivots then raise the boom with the lever pulled straight back. When the boom tops out quickly push the boom lever to the down postion and the boom will go up into the lock position.
   / Case 4 Stick Backhoe Controls - How are they? #16
I have played on the 4 stick case and IMHO once you have the extendahoe you will find it is more productive than without as you move less often. the 4 stick 2 pedel case is not hard to learn. the hard part is to park the boom as you have to reverse the stick is it reaches the top. try going from a 2 stick backhoe to a 2 stick 4 pedel excavator than a 4 stick 2 pedel back hoe
   / Case 4 Stick Backhoe Controls - How are they? #17
Is the 4th stick for the extend-a-hoe or is it for the swing? I have the 3 lever with the foot pedals for the swing but no extend-a-hoe. I like the 3 lever but I have learned how to use my wrist to push on one lever while pulling on the other two so I can uncurl the bucket to get a nice smooth trench. Until I got use to it I would be worthless on a 2 stick machine.
   / Case 4 Stick Backhoe Controls - How are they? #18
the ones I have seen the 4th stick is for the extend. I use small finger and palm , index finger and palm/thumb on the other.
2013 Ford Econoline Cargo Van (A56858)
2013 Ford...
Diamond C Trailers 26ft T/A Flatbed Tilt Trailer (A55787)
Diamond C Trailers...
UNUSED FUTURE XKH39 39" HYD 4N1 BUCKET (A57193)
UNUSED FUTURE...
BUNDLE OF 4" - 6" X 12' BUILDING PURLIN (A54757)
BUNDLE OF 4" - 6"...
2020 Chevrolet Silverado 1500 (A55315)
2020 Chevrolet...
205196 (A52706)
205196 (A52706)
