case 310 G dozer transmission
   / case 310 G dozer transmission #1
whitetail0579
twining
case 310g
I have a case 310 g bulldozer and I am in the process of replacing the mainshaft and bearings in the transmission. The mainshaft is the very top one that the driveshaft connects to. The problem I am having is that when I pulled the shaft out of the transmission the gears fell and Im not sure which way they go back in. I do have a parts manual for my dozer and do see the order that these gears and spacers go in. Im not sure which way the gears face as all 3 of my gears have collars on them. The only gear in the parts manual with a collar showing on it is the middle of the three gears and it faces the front of the dozer. Does this mean that if I cant see the collars on the other 2 gears that they must face away or to the rear? Any help would be appreciated. I thought when I pulled the shaft all the collars were to the front but now Im second guessing myself as I put the shaft in once and Ill I had was 2nd and reverse gears. Now I have the shaft and gears removed again.
2015 Kenworth T400 T/A Vactor 2100 Combination Sewer Jetter Vacuum Truck (A50323)
2015 Kenworth T400...
2015 INTERNATIONAL 4300 26 FT NON CDL BOX TRUCK (A51219)
2015 INTERNATIONAL...
2012 FREIGHTLINER CASCADIA (INOPERABLE) (A50854)
2012 FREIGHTLINER...
2000 Dnya RGN (A49461)
2014 TOYOTA 8FGCU25 FORKLIFT (A51222)
2014 TOYOTA...
2025 Swict 84in Bucket Skid Steer Attachment (A50322)
2025 Swict 84in...
