Case 1845B Hydraulic Sysyem
   / Case 1845B Hydraulic Sysyem #1
jking7489
case 450 crawler deere 3010
I have a mid 80s 1845B skid steer. Machine runs good and hydraulics are strong. It has aux hydraulics activated by a foot pedal, rear hydraulics operated by foot pedal when you pull a knob, and backhoe hydraulics (separate connectors) activated by pulling a knob as well. So my question is I’m looking to build a hydraulic driven bush hog for cutting tight areas. My research tells me I need a case drain which I do not have ( I don’t think ) would it be possible to add a case drain to loader arm so I could use my pedal or would I be better off hooking into the backhoe hydraulics and add a case drain there so I can pull a knob and it will stay on. I’m open to any and all suggestions.
   / Case 1845B Hydraulic Sysyem #2
Case drain does not go through valves it plumbs direct to the reservoir so use whichever power source works best for you
Thank you, I’m still learning about hydraulics as I go.
1270 (A50490)
1270 (A50490)
2002 FREIGHTLINER FL70 DUMP TRUCK (A51406)
2002 FREIGHTLINER...
Yale GLC050LXNVAE087 5,000lbs Propane Cushion Tire Forklift (A51691)
Yale...
2007 International 4300 Box Truck, VIN # 1HTMMAAL27H513415 (A51572)
2007 International...
