case 1490 pto problem
   / case 1490 pto problem #1
gayoung
case 1490
Hi
guys, have a problem with a 1983 Case 1490. When the PTO is under heavy load, its disengages. can anyone suggest a reason or fix? Hay season is coming up and it won,t run a round baler to a good pressure to keep bales uniform. Help please, Gary
   / case 1490 pto problem #2
Hi i have international 706 we just replaced the clutch pack in the pto on ares because it was sliping. I would see if yours has clutches they might be worn out and need to be replaced. Hope i could help out.
   / case 1490 pto problem #3
No clutch packs on the 1490 !! As it uses a clutch assy on the flywheel
Do you need a service manual, clutch and pto assy is covered in the Case IH 1490/1494/1594/1690 & 1694 service manual, which i sell as a PDF download.
If interested, send me a PM with your e mail address for further details!!
   / case 1490 pto problem #4
Hey guys just bought a 1490 and pto makes a grind noise when turn on is this normal
2025 New/Unused LandHero 1 in Air Impact Wrench (A51573)
2025 New/Unused...
10ft x 8ft Container with Side Door (A51573)
10ft x 8ft...
378658 (A51573)
378658 (A51573)
2011 PETERBILT 348 (A52472)
2011 PETERBILT 348...
2023 JOHN DEERE 8R370 LOT NUMBER 200 (A53084)
2023 JOHN DEERE...
2019 JOHN DEERE 5090M LOT NUMBER 92 (A53084)
2019 JOHN DEERE...
