Case 10 Sickle Mower, usage and maintenance
   / Case 10 Sickle Mower, usage and maintenance #1
project_X
Ottawa, ON, Canada
Kubota L235DT and L225
I have a new to me 3pt hitch Case 10 sickle mower, this is my first sickle mower so I want to get the scoop on maintenance and usage. Would anyone happen to have a manual for one of these?
I've attached some pictures, I used it cut along a drainage and in one of may fields. I found that I tended to get it full of grass, should the blades be sharper, some part of the setup to pay attention to?
More pictures
   / Case 10 Sickle Mower, usage and maintenance #3
Nice looking machine.
Here are a few thouights.
Be sure the spring on the breakaway mechanism is set loose enough that the cutter bar assembly swings back if you strike an obstacle. On my John Deere I set it loose enough that I can trip the mechanism by snatching the end of the cutterbar. I figure I don't have the strength to break it, so if it releases at my pull it is safe.
Looks like someone substituted pipe for the pittman arm. I think the pittman arm in some mowers is sort of a safety relief that will break if the knife gets jammed. Unless I knew that the mower is designed for an unbreakable pittman arm I would replace it with a wooden bar. In addition the wood absorbs some of the vibration.
The sections (the triangular "teeth") appear to be in various stages of wear. Those nearest the knife head (the tractor end) seem to be in fairly good shape. You can see that they still have most of the serrations. But those farther out the cutterbar look very worn; if they ever had serrations they no longer do. I think serrated sections are much better than smooth ones for cutting most everything. Sections are only a couple of dollars each (you need four per foot), so they can be replaced at reasonable cost. I would use bolts instead of rivets when replacing them because it is easier (to me).
The hold downs (the five or six adjustable pieces bolted to the top of the cutterbar) are used to keep the sections pressed against the cutting edges (ledgers) of the guards (the pointy things sticking off the front of the cutterbar). They should put enough pressure on the sections to keep the bottom edge of each section against the ledgers of the guards, but not so much pressure that they wear the guards. The way to test this is to run it for a few minutes and then see if any of the hold downs are too hot to touch; that is a sign that the holddown is too tight. Many years ago, when our father was not around, my brother and I would pee on the hold downs; if they didn't steam we figured all was okay.
As sickle mowers are used, the knife back (the 1/4 x 3/4 inch steel bar that holds the sections) tends to warp. A rock may lodge between a section and guard; even though nothing breaks the knife back may be slightly twisted or bent. Over the years the knife back can become fairly squiggley. At some point the sections don't fit against the guard ledgers very well, and instead of being cut the grass just gets mangled; the grass finally parts, but only because the cutterbar is moving forward and drags it over the sections.
Guards are $10-12 each and you need two per foot of cutterbar.
Finally, under each hold down should be a thin piece of metal with a bent down edge toward the front; these wear plates keep the knife back from touching and wearing the cutter bar. Be sure your wear plates are not so worn that the cutterbar is being worn. They a only a couple of dollars each.
I have two sickle mowers and enjoy mowing with them much more than my rotary mowers. But I got both of them (well) used and they began to perform properly only after I replaced the knives (the sections and knifeback), guards, hold downs (get the ones that adjust with a hex screw), and wear plates. That may be $200 or so, even if you shop the aftermarket places, but it sure makes it nice.
Farmerford,
Thanks for the detailed info.
My spring is likely too tight. I will look into adjusting that.
The some of the sections are serrated and some (which appear older) are smooth (and likely were never serrated)
Thanks,
Rob
   / Case 10 Sickle Mower, usage and maintenance #5
I have a manual and two of these mowers. One's a trailer and one is 3pt hitch. If you still need a copy of a manual let me know.
I'd love a copy, PM sent
   / Case 10 Sickle Mower, usage and maintenance #7
I hope this is going to be read - I just acquired a 3PT version Case 10 and need to replace the pittman arm, but I don't have a manual nor know the size, etc needed. I would love a copy of the manual, but just some advice on the arm at this point is needed.
thanks
Danielle:turtle:
   / Case 10 Sickle Mower, usage and maintenance #8
I've been trying to send the manual, but it is too big for any email account. I scanned it in pretty high resolution and the whole book is 26 megs. So, I put it up on one of my Web sites as a download. It is a PDF and you can download it at Case T-10 Manual.
thanks
Danielle:turtle:
   / Case 10 Sickle Mower, usage and maintenance #9
Good morning, is this post still active and does anyone have a copy of the Case 10 Sickle Mower manual still handy? I just picked one up this weekend and need to order some parts and get her back in the game for hay season. I tried the Case T-10 Manual link in sjerden's post and it takes me to a different website and I could not find the manual there. Thanks for your time and consideration.
   / Case 10 Sickle Mower, usage and maintenance #10
I'll put the t-10 manual back up on my test server tonight.
Dump Truck Body with Tarp System (A55851)
Dump Truck Body...
500 BBL WHEELED FRAC TANK (A55745)
500 BBL WHEELED...
2015 Ford Fusion Sedan (A55853)
2015 Ford Fusion...
2012 Ford F-250 4x4 Ext. Cab Pickup Truck (A56858)
2012 Ford F-250...
2013 Ford F-450 Dump Truck (A55852)
2013 Ford F-450...
2018 Autocar ACX Xpeditor T/A Hercules Front Loader Garbage Truck (A55852)
2018 Autocar ACX...
